10-23-2013 09:10 AM - edited 03-01-2019 07:26 AM
Hi Folks,
I am getting below error while trying to create VDC. As per my knowledge by default 4 VDC's are allowed without VDC license.
CS7009-A(config)# vdc Production
ERROR: VDC create failed: License restrictions precludes further vdc creation
CS7009-A# sh vdc
vdc_id vdc_name state mac type lc
1 CS7009-A active 84:78:ac:13:22:c1 Ethernet f2
CS7009-A# sh license usage
Feature Ins Lic Status Expiry Date Comments
Count
MPLS_PKG No - Unused -
STORAGE-ENT No - Unused -
VDC_LICENSES No 0 Unused -
ENTERPRISE_PKG No - Unused -
FCOE-N7K-F132XP No 0 Unused -
FCOE-N7K-F248XP No 0 Unused -
ENHANCED_LAYER2_PKG No - Unused -
SCALABLE_SERVICES_PKG No - Unused -
TRANSPORT_SERVICES_PKG No - Unused -
LAN_ADVANCED_SERVICES_PKG No - Unused -
LAN_ENTERPRISE_SERVICES_PKG Yes - Unused Never -
ADM-G-CS7009-A# sh module
Mod Ports Module-Type Model Status
1 0 Supervisor module-2 N7K-SUP2 active *
3 48 1/10 Gbps Ethernet Module N7K-F248XP-25E ok
Mod Sw Hw
1 6.1(2) 1.1
3 6.1(2) 1.0
Mod MAC-Address(es) Serial-Num
1 84-78-ac-1c-08-41 to 84-78-ac-1c-08-53 JAF1720AJGQ
3 84-78-ac-1d-95-c8 to 84-78-ac-1d-95-fb JAF1721ATKR
Mod Online Diag Status
1 Pass
3 Pass
Xbar Ports Module-Type Model Status
1 0 Fabric Module 2 N7K-C7009-FAB-2 ok
2 0 Fabric Module 2 N7K-C7009-FAB-2 ok
3 0 Fabric Module 2 N7K-C7009-FAB-2 ok
Xbar Sw Hw
1 NA 3.2
2 NA 3.2
3 NA 3.2
Please help
10-24-2013 04:55 AM
As per the error message, I think that the problem you have is due licensing.
As per Table 1: Feature-Based Licenses for the Cisco Nexus 7000 Series in the Cisco NX-OS Licensing Guide, to use VDC you need the Advanced Services License.
Additionally according to the Licensing Requirements for VDCs section of the Cisco Nexus 7000 Series NX-OS Virtual Device Context Configuration Guide:
Without a license, the following restrictions will prevent you from creating additional VDCs:
- Only the default VDC can exist and no other VDC can be created.
- On all supported Supervisor modules, if you enable the default VDC as an admin VDC, you can only enable one nondefault VDC.
The show license usage you included within your post indicates that you have neither the Advanced Services License nor VDC License and this means you're restricted according to the bullet points above.
If you need to use VDC now then you need to purchase the Advanced Services license. Note that you can enable a 120-day grace period with the license grace-period command within global context such that you could at least get the router configured as you want it, and install the license when you get it. Beware that any features enabled under a license grace period will be disabled at the end of the 120-days so ensure you get the license if you take this approach.
If you don't need VDC immediately or are not sure if you'll ever need them, then it may still be worth configuring the default VDC as the admin VDC, and then create a nondefault VDC as per the second bullet above. This would simplify matters at a later stage if you did want to add VDC.
02-19-2017 09:12 PM
Dear All ,
We have purchased Nexus 7K with SUP 2E and LAN enterprise license(N77-LAN1K9) and SAN & LAN Advanced license(DCNM-LS-N77-K9) .
Can you tell me whether we can configure VDC using this features as we did not purchase additional VDC license .
I am keenly waiting for your reply soon.
With regards
Erfan
03-14-2016 07:50 PM
HI ,have you resolved this issue?
