Nexus 7010 - SUP 1- CMP No response
SBD Warranty
Hi Everyone.
i have two Nexus devices, last week i upgraded from NXOS 6.03 to 6.1(5a), but when the device had done, i saw the CMP module no response status in on SUP.
Here is output in two devices. Everyone have any idea about it.
SB-CORE-NX7010-001# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 3.22.0
  kickstart: version 6.1(5a)
  system:    version 6.1(5a)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.6.1.5a.bin
  kickstart compile time:  12/25/2020 12:00:00 [10/06/2014 02:11:42]
  system image file is:    bootflash:///n7000-s1-dk9.6.1.5a.bin
  system compile time:     10/3/2014 17:00:00 [10/06/2014 03:22:02]
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 4104300 kB of memory.
  Processor Board ID JAF1304AGAQ
  Device name: SB-CORE-NX7010-001
  bootflash:    2030616 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 1 day(s), 6 hour(s), 38 minute(s), 51 second(s)
Last reset
  Reason: Unknown
  System version: 6.1(5a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
  CMP BIOS version:        02.01.05
  CMP Image version:       4.0(4) [build 4.0(4)]
  CMP BIOS compile time:   7/13/2008 19:44:27
  CMP Image compile time:  10/20/2008 12:00:00
CMP (Module 6) no response
SB-CORE-NX7010-001#
SB-CORE-NX7010-002# show version
Software
Hardware
  Processor Board ID JAF1306AMTC
  Device name: SB-CORE-NX7010-002
Kernel uptime is 1 day(s), 6 hour(s), 43 minute(s), 57 second(s)
Last reset at 566133 usecs after  Sun Mar 22 03:39:09 2015
  Reason: Reset triggered due to Switchover Request by User
  Service:
plugin
CMP (Module 5) ok
CMP Software
SB-CORE-NX7010-002#
I need understand that you need to make a upgrade to cmp? or do you did a upgrade of cmp?
Hi Ney
I upgraded the new IOS, and reload CMP alreadly had done. But i don't know why CMP no response.
do you have any idea about it?
did you upgrade CMP, because could be that with the new upgrade to nx-os not responde the CMP.
if you want you check verify that documentation in that link.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/hw/nexus7000/cmp/configuration/guide/n7cmp/n7cmp_configuring.html
Hi Ney
we only upgraded new IOS with traditional method. After that, we reloaded cmp module.
we already done it with other devices, but this case we had problem.
Do you have any idea for it?
