We are trying to migrate N7000 (F2) to N7700 (F3). While copying configuration and reloading N77 we see following error
....Tcam will be over used, please enable bank
chaining and/or turn off atomic update.If bank-chaining is enabled on other modules
and this is a new linecard insertion,please enable bank-chaining prior to reloading
this module.
Looking further into the mater reveals that it is the atomic updates that stops it.
When we dig down further
Show hardware access-list resource entries module x
on N7000 shows total approx 8000 entries for all 4 banks having 2 vdc + admin
while N7700 shows only 4000 entries for all 4 banks having 2 vdc + admin
gw01# show hardware access-list resource utilization module 1
INSTANCE 0x0
ACL Hardware Resource Utilization (Mod 1)
Used Free Percent
Utilization
Tcam 0, Bank 0 20 4076 0.49
Tcam 0, Bank 1 20 4076 0.49
Tcam 1, Bank 0 25 4071 0.61
Tcam 1, Bank 1 440 3656 10.74
LOU 4 100 3.84
Both LOU Operands 2
Single LOU Operands 2
LOU L4 src port: 1
LOU L4 dst port: 1
LOU L3 packet len: 0
LOU IP tos: 0
LOU IP dscp: 0
LOU ip precedence: 0
LOU ip TTL: 0
TCP Flags 0 16 0.00
Protocol CAM 3 20 13.04
Mac Etype/Proto CAM 11 3 78.57
Non L4op labels, Tcam 0 0 1535 0.00
Non L4op labels, Tcam 1 1 1534 0.06
L4 op labels, Tcam 0 0 491 0.00
L4 op labels, Tcam 1 1 490 0.20
Ingress Dest info table 1 252 0.39
Egress Dest info table 0 256 0.00
# sh system internal access-list globals
slot 1
Atomic Update : ENABLED
Default ACL : DENY
Bank Chaining : DISABLED
Seq Feat Model : NO_DENY_ACE_SUPPORT
This pltfm supports seq feat model
Bank Class Model : DISABLED
This pltfm supports bank class model
Fabric path DNL : DISABLED
L4 proto CAM extend : DISABLED
This pltfm supports L4 proto CAM extend
This pltfm does use L4 proto CAM
MPLS Topmost As Pipe Mode : DISABLED
This pltfm supports mpls topmost as pipe mode
LOU Threshold Value : 5
I wonder what determines these resource entries and how can I set a higher resource entries for certain vdc ?
