Nexus 7K Upgrade issue
s.lachica
Anyone who can help explain and solve the issue below:
# show install all impact kickstart n7000-s1-kickstart-npe.6.1.4a.bin system n7000-s1-dk9-npe.6.1.4a.bin
Verifying image bootflash:/n7000-s1-kickstart-npe.6.1.4a.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin.
Extracting "kickstart" version from image bootflash:/n7000-s1-kickstart-npe.6.1.4a.bin.
Extracting "bios" version from image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin.
Extracting "lc1n7k" version from image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin.
Extracting "cmp" version from image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin.
Extracting "cmp-bios" version from image bootflash:/n7000-s1-dk9-npe.6.1.4a.bin.
Performing module support checks.
Notifying services about system upgrade.
[#                   ]   0% -- FAIL.
Return code 0x40B30029 (Operation failed. Fabric is already locked).
Pre-upgrade check failed. Return code 0x40B30029 (Operation failed. Fabric is already locked).
CCIE (R&S) #27666 CCSI HP MASE
datamodule
check any one else is using your switch using the following command
switch(config)# show cfs lock
Check the output
If you are happy no one is doing any changes
run the following command to clear
switch(config)# clear device-alias session
Worked great for me on a MD9148-32
