Nexus 9332PQ with FEX 2348UPQ
Xavillon
I try to connect a parent 9332PQ with a FEX 2348UPQ.
The configuration is the following:
interface port-channel125
description FEX125
switchport
switchport mode fex-fabric
fex associate 125
vpc 125
interface Ethernet1/3
description FEX125
switchport
fex associate 125
channel-group 125
no shutdown
I used QSFP-H40G-CU1M between them.
I can see the led from N2K green but on N9K there is no activity and it is in not connect?
Do you known why  I can't see the FEX?
Thank you.
M.
Rick1776
Level 5
Level 5
Don't put the switchport mode fex under the interface only the port-channel as the example below...
interface ethernet 1/28
switch(config-if)# channel-group 4
switch(config-if)# no shutdown
switch(config-if)# exit
switch(config)# interface ethernet 1/29
switch(config)# interface ethernet 1/30
switch(config)# interface ethernet 1/31
switch(config)# interface port-channel 4
switch(config-if)# switchport
switch(config-if)# switchport mode fex-fabric
switch(config-if)# fex associate 101
Please see the following link as well...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus2000/sw/configuration/guide/n9k_rel_612I24/b_Cisco_Nexus_2000_Series_NX-OS_Fabric_Extender_Configuration_Guide_for_Cisco_Nexus_9000_Series_Switches_Release_6x/b_Cisco_Nexus_2000_Series_NX...
