Nexus uplinks Amber color
ahurtadove
This may be a dumb question but I would like to know why the uplink ports of a fabric extender are in amber color.
when I issue the command show fex xxx detail and show diagnostistic it gives me this output:
N5K# Show fex 102 detail
FEX: 102 Description: FEX0102   state: Online
  FEX version: 4.1(3)N1(1a) [Switch version: 4.1(3)N1(1a)]
  FEX Interim version: 4.1(3)N1(1a)
  Switch Interim version: 4.1(3)N1(1a)
  Extender Model: N2K-C2148T-1GE,  Extender Serial: xxxxxxxxx
  Part No: 73-12009-05
  Card Id: 70, Mac Addr: 00:0d:ec:ce:6f:02, Num Macs: 64
  Module Sw Gen: 12338  [Switch Sw Gen: 20]
pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/9
  Fabric interface state:
    Po102 - Interface Up. State: Active
    Eth1/9 - Interface Up. State: Active
    Eth1/10 - Interface Up. State: Active
  Fex Port        State  Fabric Port  Primary Fabric
       Eth102/1/1  Down       Po102       Po102
       Eth102/1/2    Up       Po102       Po102
       Eth102/1/3    Up       Po102       Po102
       Eth102/1/4    Up       Po102       Po102
       Eth102/1/5    Up       Po102       Po102
       Eth102/1/6  Down       Po102       Po102
       Eth102/1/7    Up       Po102       Po102
       Eth102/1/8    Up       Po102       Po102
       Eth102/1/9    Up       Po102       Po102
      Eth102/1/10    Up       Po102       Po102
      Eth102/1/11  Down       Po102       Po102
      Eth102/1/12  Down       Po102       Po102
      Eth102/1/13  Down       Po102       Po102
      Eth102/1/14  Down       Po102       Po102
      Eth102/1/15  Down       Po102       Po102
      Eth102/1/16  Down       Po102       Po102
      Eth102/1/17  Down       Po102       Po102
      Eth102/1/18  Down       Po102       Po102
      Eth102/1/19  Down       Po102       Po102
      Eth102/1/20  Down       Po102       Po102
      Eth102/1/21    Up       Po102       Po102
      Eth102/1/22  Down       Po102       Po102
      Eth102/1/23  Down       Po102       Po102
      Eth102/1/24    Up       Po102       Po102
      Eth102/1/25  Down       Po102       Po102
      Eth102/1/26  Down       Po102       Po102
      Eth102/1/27  Down       Po102       Po102
      Eth102/1/28  Down       Po102       Po102
      Eth102/1/29  Down       Po102       Po102
      Eth102/1/30  Down       Po102       Po102
      Eth102/1/31  Down       Po102       Po102
      Eth102/1/32  Down       Po102       Po102
      Eth102/1/33  Down       Po102       Po102
      Eth102/1/34  Down       Po102       Po102
      Eth102/1/35  Down       Po102       Po102
      Eth102/1/36  Down       Po102       Po102
      Eth102/1/37  Down       Po102       Po102
      Eth102/1/38  Down       Po102       Po102
      Eth102/1/39  Down       Po102       Po102
      Eth102/1/40  Down       Po102       Po102
      Eth102/1/41  Down       Po102       Po102
Logs:
[10/27/2011 15:23:52.351003] Module register received
[10/27/2011 15:23:52.354119] Registration response sent
[10/27/2011 15:23:52.408755] Module Online Sequence
[10/27/2011 15:23:53.683804] Module Online
[10/27/2011 15:27:25.738784] Module disconnected
[10/27/2011 15:27:25.739876] Offlining Module
[10/27/2011 15:27:25.740381] Module Offline Sequence
[10/27/2011 15:27:28.75862] Module Offline
[10/27/2011 15:29:26.556690] Module register received
[10/27/2011 15:29:26.560015] Registration response sent
[10/27/2011 15:29:26.616726] Module Online Sequence
[10/27/2011 15:29:28.51180] Module Online
N5K# Show diagnostic result fex 102
FEX-102: 48x1GE/Supervisor  SerialNo   : xxxxxxx
Overall Diagnostic Result for FEX-102  : OK
Test results: (. = Pass, F = Fail, U = Untested)
TestPlatform:
0)            SPROM: ---------------> .
1)        MV88E6095: ---------------> .
2)              Fan: ---------------> .
3)      PowerSupply: ---------------> .
4)       TempSensor: ---------------> .
TestForwardingPorts:
Eth    1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
Port ------------------------------------------------------------------------
Eth   25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
TestFabricPorts:
Fabric 1  2  3  4
Port ------------
I see that the hardware is ok but all the ports are still amber, it gives l2 conectivity and works ok but this has been asked to me and is a real p in the a to find led color meanings for nexus.
thank you, points will be given.
nkarpysh
Hi Antonio,
Are you using 3rd party transceivers? Do you have command "'service unsupported-transceivers'" enabled. If yes then this explains the problem - ports are working fine while controller does not understand it as it is not supporting those transceivers. If this posibility rulls out then another questions is if FEX passed the POST test after it was connected with N5k?
this is BTW the LED table:
on the FEX, there are five types of LED as indicate below.
* System status: green (operational), amber (fault), flashing amber (POST boot up), off
(no power)
* Locator LED: bright blue locator
* Port status: green (link established), amber (administratively disabled), flashing amber
(fault)
* Fan status: green (operational), amber (fault)
* Power status: green (operational), amber (fault)
(for more detail:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html )
Hope this helps,
Nik
HTH,
Niko
