Nexus vPC connection
Xiangzhen Quan
Hi team
Here are two Nexus vPC questions need help~
If a IBM server LAN card is in Active-Standby mode,Does the Nexus vPC running normallywithout other configuration?
If some device are installed windows/linux/unix OS,  and LAN card is in Active-Active/Active-standby mode, does the Nexus vPC running normally without other configuration?
Best regards
QxiangZh
Chad Peterson
Hi Quan,
if your IBM server is running active-standby, you should not use vPC to connect to it...just use two individual links.
If the NIC is active/active you will want to connect to it though vPC...so configure vpc on the Nexus, and on the server you will want to do nic-teaming.
Hope that helps
Chad
Hello Chad..
Thanks for you reply..
So, wo cannot connect to active-standby port via vPC,
But we can connect to active-active port, but should configure vPC to NIC-teaming, right??
I am sorry but I am new in this technology~ So I need double confirm
Many thanks~
QxiangZh
