No console output on Nexus5020 after FW upgrade
vijay.gaganam
Cisco Nexus 5020 Firmware is  upgraded. Upgrade was successfull without any issue. After reboot  nothing comes up on the console. Tried rebooting a couple of times.  nothing comes up on the console, not even the inital Bios output.
Anybody know if its a hardware or software issue.
Upgrade procedure followed.
Cisco5020# copy ftp bootflash:n5000-uk9.4.2.1.N1.1.bin
Enter vrf (If no input, current vrf 'default' is considered): management
Enter username: **********
Password: *************
***** Transfer of file Completed Successfully *****
Cisco5020# copy ftp bootflash:n5000-uk9-kickstart.4.2.1.N1.1.bin
install all system bootflash:n5000-uk9.4.2.1.N1.1.bin kickstart bootflash:n5000-uk9-kickstart.4.2.1.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.4.2.1.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.4.2.1.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.4.2.1.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.4.2.1.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.4.2.1.N1.1.bin.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable         Impact Install-type Reason
     1       yes     disruptive         reset Reset due to single supervisor
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version Upg-Required
     1     system             4.1(3)N1(1)             4.2(1)N1(1)           yes
     1   kickstart             4.1(3)N1(1)             4.2(1)N1(1)           yes
     1       bios       v1.2.0(06/19/08)                                   no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)? [n] y
Install is in progress, please wait.
Setting boot variables.
Performing configuration copy.
Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
Warning: please do not remove or power off the module at this time.
Finishing the upgrade, switch will reboot in 10 seconds.
Cisco5020#
Broadcast message from root (Thu Aug 26 21:14:55 2010):
The system is going down for reboot NOW!
Jerry Ye
Duplicated post. Respond to your other post on LAN Switching Forum already.
https://supportforums.cisco.com/message/3404374#3404374
jerry
