NX-OS 6.1 + sup1 + N7K-F248XP-25 = no FCOE
jnantel
So we bought 2 x Nexus 7009 to replace our aging datacenter infrastructure with the hope of moving to the latest generation of technology and features from Cisco. What we needed was 10gigE support and FCoE capabilities to connect our EMC VNX 5500
We bought the following:
2 x sup1 (for ISSu)
1 x N7k-F248XP-25
1 x N7k-M132XP-12L
5 x FAB2s
1 x SBUN advanced license pack (OTV,FCoE,DCNM,EL2,TRS..etc.)
I finally get around to registering/configuring and licensing these units. So I download the latest NX-OS 6.1, which had the features we were promised (FCOE with multihop) and behold it fails compatibility check prior to upgrade.  I do a little research on the release notes for 6.1 and I run into the following statement:
FCoE Support
The 48-port 1/10-Gigabit Ethernet SFP+ F2-series I/O module (N7K-F248XP-25) supports FCoE, and requires either the Supervisor 2 or Supervisor 2E module, and the N7K-FCOEF248XP license.
Does anyone know if there is planned FCOE support for 6.1 and Sup1 with above configuration? Is there a way that anyone has run into this issue? And does anyone have any recommendations or insight on this issue?
I've already taken this up with my sales agent, in the meantime I have a ton of projects pilling because this thing isn't in production.
haihuang
Yes, you need either Sup2 or Sup2E and license to support FCoE on F2 card.
Additionally, I noticed that you also have M1 card in the config. Just to remember that F2 and M1 cannot co-exist in same VDC.
