OSPF not advertising routes over GRE tunnel on 9k
Nitesh_A
Hello experts,
Question:
I have WAN-R1 and WAN-R2 connected to ISP and have GRE tunnel between WAN-R1&WAN-R2 (bgp as underlay and ospf as overlay). Tunnel is up on both WAN routers, however i am not able to advertise routes from WAN-R1 to WAN-R2.
Topology: https://www.autodraw.com/share/DN7AZ0BXMAP3
WAN-R1(config)# sh ip ospf nei vrf DC
OSPF Process ID DC VRF DC
Total number of neighbors: 1
Neighbor ID Pri State Up Time Address Interface
10.100.2.21 FULL/ - 00:02:14 10.100.2.2Tunnel100
WAN-R2# sh ip ospf nei vrf DC
10.100.2.11 FULL/ - 00:02:37 10.100.2.1Tunnel100
On WAN-R1 :
ip prefix-list DC_subnet seq 10 permit 10.2.2.0/28
ip prefix-list DC_subnet seq 20 permit 10.3.3.0/28
ip prefix-list DC_subnet seq 30 permit 172.16.0.0/29
ip prefix-list DC_subnet seq 40 permit 192.168.1.0/28
route-map DC permit 10
match ip address prefix-list DC_subnet
vrf context DC
ip route 10.2.2.0/28 10.100.5.2
ip route 10.3.3.0/28 10.100.5.2
address-family ipv4 unicast
router ospf DC
router-id 10.100.1.1
redistribute direct route-map DC (tried static keyword after redistribute also)
vrf DC
But don't see any routes on WAN-R2
WAN-R2# sh ip route ospf vrf DC
IP Route Table for VRF "DC"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
WAN-R2#
Any suggestion would be helpful for me.
Thankyou
Sergiu.Daniluk
Hi @Nitesh_A
Looks like the redistribution is not configured under the vrf DC section of the OSPF.
The config should look like:
router ospf DC
  vrf DC
    redistribute static route-map DC
Cheers,
Sergiu
Sergiu.Daniluk
Hi @Nitesh_A
router ospf DC
  vrf DC
Cheers,
Sergiu
Nitesh_A
@Sergiu.Daniluk
Thankyou for the help. It worked
WAN-R1(config-router-vrf)# sh run | sec ospf
feature ospf
ip router ospf DC
router ospf 10
router-id 10.123.10.1
router ospf DC
vrf DC
WAN-R2# sh ip route vrf DC
10.2.2.0/28, ubest/mbest: 1/0
*via 10.100.2.1, Tunnel100, [110/20], 00:05:07, ospf-DC, type-2
10.3.3.0/28, ubest/mbest: 1/0
10.100.2.0/29, ubest/mbest: 1/0, attached
*via 10.100.2.2, Tunnel100, [0/0], 00:44:32, direct
10.100.2.2/32, ubest/mbest: 1/0, attached
*via 10.100.2.2, Tunnel100, [0/0], 00:44:32, local
10.100.5.0/29, ubest/mbest: 1/0
*via 10.100.2.1, Tunnel100, [110/20], 00:06:35, ospf-DC, type-2
10.100.100.1/32, ubest/mbest: 1/0
*via 10.100.2.1, Tunnel100, [110/11112], 00:44:16, ospf-DC, intra
WAN-R2# ping 10.100.5.2 vrf DC
PING 10.100.5.2 (10.100.5.2): 56 data bytes
64 bytes from 10.100.5.2: icmp_seq=0 ttl=253 time=26.693 ms
64 bytes from 10.100.5.2: icmp_seq=1 ttl=253 time=28.827 ms
64 bytes from 10.100.5.2: icmp_seq=2 ttl=253 time=29.641 ms
64 bytes from 10.100.5.2: icmp_seq=3 ttl=253 time=29.825 ms
64 bytes from 10.100.5.2: icmp_seq=4 ttl=253 time=29.224 ms
Can't we configure crypto map on 9k? do we require any type of license. I don't see crypto map isakmp keyword like such.
WAN-R2(config)# crypto ?
ca Configure certificate authority related information
cert Configure certificate maping filter settings
certificatemap Configure certificatemap filters
key Configure key pair related information
Hi @Nitesh_A
IPsec is not a feature supported on N9K. Remember these are DC switches, focused on data center related technologies. IPsec over GRE is not really a data center technology (debatable). So using the N9K as a wan router might not be the best solution. You should also consider the routing table scalability limits: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/scalability/guide-931/b-Cisco_Nexus-9000-Series-NX-OS-Verified-Scalability-Guide-931.html
Cheers,
Sergiu
P.S. Don't forget to mark answers as correct if it solves your problem.
