Above is the working OTV device output. Does this means that we can transport only packets of MTU 1400 through OTV ? is this MTU considers only the payload or with headers ? if with headers upto which header it calculates ?
No it doesn't mean the device is only able to transport 1400 bytes packet. This value is the MTU of ISIS control packet. You can try a very simple test if you can affort an outage:
- change the OTV joint interface's MTU to 1000
- shut, no shut the overlay interface
- at this point, OTV will not come up. You can verify it by using show otv isis adj
- once you change to joint interface's MTU back to 1500, OTV will come up
How big of the MTU can OTV transport? It is depends on the path MTU size.
HTH,
jerry
