OTV QUESTION
ccnaguru
For unicast OTV configuration do you need the command
                                                            mtu 9216
on the link's E1/2 on both side going into the cloud to the other Data Center?
It looks as both options add the extra 42byte size so you’ll need to support the minimum of 1542/1550. I have heard other using a ASR with a 1500 MTU but not on the Nexus 7Ks
Rick1776
Level 5
Level 5
What device is your AED an ASR or Nexus 7k?
AED is a 7K.
What about if it is an ASR
