P2P connectivity in VSS enabled switches
Pranav Mhatre
Hi Team,
I want to connect 2 locations which have 4500 X core switches in which VSS is enabled.
As per my knowledge to achieve redundancy using multi-chassis etherchannel, A is better option however is there any pros /cons from IOS / Hardware/ Configuration / SFP point of view which you have experienced / Know about that need to be considered before implementing either of attached options.
Let me know if in case any other scenarios is better than A to achieve redundancy(100 % network availability) .
Dan Lukes
You should not ask in random communities unrelated to the topic of question if you wish for valuable response.
Please use blue [ EDIT ] button on top to move thread to LAN, Switching and Routing
