VEM lost contact with VSG Hyper-V, 0.0.0.0 ARP and vemlog errors
mozmorris1974
We had 3 VEM lose connectivity to the VSG, they were working for at least 6 months
Luckily 1 lost contact whilst investigating (log below)
We can see no changes within VMM.
I wiresharked the network
The VEM which have an issue do an ARP broadcast for the VSG the sender IP is 0.0.0.0, nothing is returned by the Cisco 4510
The VEM which are working do an ARP broadcast for the VSG the sender IP is that of the vDATA IP hyperV host- good
I looked into the logs of the vemlog on the Windows Host and can see the following entries, they would tally with the 0.0.0.0 ARPS
The hosts do have an IP address defined within VMM for the vdata connection.
Sep 07 16:05:47.005878    648111  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 0 new sgid 32
Sep 07 16:05:47.005878    648112  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:05:47.005878    648113  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 32 new sgid 0
Sep 07 16:05:47.005878    648114  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:06:08.521475    648115   0   99  1   Error sf_report_eid_stats: Could not alloc memory for stats structure. Exiting.
Sep 07 16:06:27.005727    648116  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 0 new sgid 32
Sep 07 16:06:27.005727    648117  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:06:27.005727    648118  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 32 new sgid 0
Sep 07 16:06:27.005727    648119  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:06:27.005727    648120  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 0 new sgid 32
Sep 07 16:06:27.005727    648121  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:06:27.005727    648122  12    1  8    Info [sf_platform_process_pinning_change]: Veth LTL 16 old sgid 32 new sgid 0
Sep 07 16:06:27.005727    648123  12    1  1   Error ProcessPinningUpdateDeferred: Not a virtual port ltl 16
Sep 07 16:08:11.724180    648124   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:08:11.724180    648125   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:08:41.724194    648126   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:08:41.724194    648127   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:09:11.724017    648128   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:09:11.724017    648129   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:09:41.723888    648130   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:09:41.723888    648131   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:10:11.723811    648132   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:10:11.723811    648133   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:10:25.614363    648134   0   99  1   Error VSVC-INFO: heap alloc failed, size 36879
Sep 07 16:10:41.723732    648135   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:10:41.723732    648136   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:11:11.723645    648137   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
Sep 07 16:11:11.723645    648138   0   99  4 Warning sf_query_ip_handler: Cannot get IP for vmknic vPath-CiscoVEM
Sep 07 16:11:41.723529    648139   0   99  4 Warning Error allocating memory needed to call GetAdapterInfo
the VEM are responding on thier IP addresses on the network and can bee seen in the ARP table on the 4510.
mozmorris1974
a restart of the 1000V service on the hyper-V host resolved this.
