Problem with sh int status on a Nexus 5596
Aret Avedis SET
I have maybe a bug on my Nexus 5596 switch ; when i issue the command show interface status the outpout of the "port" is missing :
# sh int statu
Port          Name               Status    Vlan      Duplex  Speed   Type
connected trunk     full    10G     1/10g
disabled  trunk     full    10G     1/10g
sfpAbsent 1         full    10G     1/10g
Eth1/7        ### ***********- connected trunk     full    10G     1/10g
Eth1/8        ### *************- connected trunk     full    10G     1/10g
disabled  1         full    10G     1/10g
connected 1         full    10G     1/10g
SDP timed 1         full    10G     1/10g
But we see the fex interfaces :Eth101/1/1, Eth103/1/1, etc...
Eth101/1/1    *** ****************connected       full    1000    --
Eth101/1/2    *** *************** connected      full    1000    --
Eth101/1/3    **
I have other 5596 with the same version 5.0(3)N2(2a) and there is no problem ; i do nothing for this, it was working before but now it's not.
Did you seen this problem before ?
Thanks for your feedback.
vdsudame
on this switch, do you remember copying any files created via windows/dos to the running config lately? can you paste a sample  'show interface ethernet x/y' for the port which is missing the port information in 'show int status'
Thanks, Vinayak
Yes when i implement a config, i always work with notepad or word and copy/paste the configuration on the Nexus.
Here is the outpout that you asked :
N5K# sh int eth1/19
Ethernet1/19 is down (SFP validation failed)
  Hardware: 1000/10000 Ethernet, address: 547f.ee92.1e1a (bia 547f.ee92.1e1a)
  Description:
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is access
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 giants  0 input error  0 short frame  0 overrun   0 underrun
    0 watchdog  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
And an outpout for an interface that is working :
N5K# sh int eth1/7
Ethernet1/7 is up
  Description:
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  EtherType is 0x8100
  Last link flapped 1week(s) 0day(s)
  30 seconds input rate 61184 bits/sec, 7648 bytes/sec, 41 packets/sec
  30 seconds output rate 109040 bits/sec, 13630 bytes/sec, 55 packets/sec
    input rate 55.00 Kbps, 32 pps; output rate 162.62 Kbps, 74 pps
  RX
    28917792 unicast packets  6436428 multicast packets  2340725 broadcast packets
    37694945 input packets  9441476437 bytes
    1471043 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    427409737 unicast packets  91135 multicast packets  414674 broadcast packets
    427915546 output packets  44591976368 bytes
    1729034 jumbo packets
    0 Tx pause
  1 interface resets
Thanks for your help
Thanks. There could be an issue with line characters after copying over the config from your notepad in windows. You can refer to the following command
nexus# d?
  debug         Debugging functions
  debug-filter  Enable filtering for debugging functions
  delete        Delete a file or directory
  diff-clean    Remove temp files created by '| diff' filters
  dir           List files in a directory
  dos2nxos      DOS to NXOS text file format converter <<<<
nexus# dos2nxos ?
  bootflash:  Filename to be displayed
  debug:      Filename to be displayed
  modflash:   Filename to be displayed
  usb1:       Filename to be displayed
  volatile:   Filename to be displayed
since you copy the configs frequently, you can use the dos2nxos command to convert the file to nxos first and then use the file for configuration. Right now, try to modify the config manually on the switch interfaces and see if that helps. You either readd 'description' command under the interface and check if the port starts showing up in 'show int status' or modify or repaste the entire interface config and check if that works.
Thanks, Vinayak
Thanks for the support ! after readding the description on the interfaces, the sh int status is now ok !
Thanks again !
