Question about NX7K QoS for iSCSI
gwhuang5398
Level 2
Level 2
I have a NX7009 with 2232 FEX attached. Software release is the latest. Plan to use NX7009 to connect to SAN using iSCSI. What kind of QoS on the NX7009 should I configure to support iSCSI? Is it type "network qos"?
From NX7009 perspective, how does it identify iSCSI traffic when it's IP encapsulated? If there's a sample I can reference, that'll be great.
Thanks in advance.
Gary
sean_evershed
Level 7
Level 7
Have you seen the QoS Nexus config guide for v6? There is a section there on iSCSI
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/qos/configuration/guide/nt_qos.html
Here also is a post from last year on an iSCSI QoS policy
https://supportforums.cisco.com/thread/2158695
Don't forget to rate all helpful posts.
