Recovery a VPC after an outage.
jramirez
Hello, I have two Nexus 7000 in a VPC settings. After restarting one of them, VPC services stopped working and servers experienced a traffic cut in their LAN cards. I used the domain command "Reload Restore" in version 5.1, but the problem persists. Any ideas?   Thanks.
Pablo.
5 Replies 5
Oleksandr Nesterov
Hi - please add
"sh run vpc"  and "sh vpc" to see in what state are the links.
Alex
jramirez
NX-CCSS-1# sho run vpc
!Command: show running-config vpc
!Time: Mon May  7 15:15:41 2012
version 5.0(5)
feature vpc
vpc domain 1
  role priority 16380
  system-priority 16384
  peer-keepalive destination 172.31.100.2 source 172.31.100.1 vrf VPC-KA
  reload restore delay 600
interface port-channel11
  vpc peer-link
interface port-channel100
  vpc 100
interface port-channel101
  vpc 101
interface port-channel102
  vpc 102
interface port-channel135
  vpc 135
NX-CCSS-1# sho vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Type-2 consistency status       : success
vPC role                        : primary, operational secondary
Number of vPCs configured       : 32
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
vPC Peer-link status
id   Port   Status Active vlans
1    Po11   up     409-410,412-414,416-418,420-421,432-434,450-452,462,471,501,504,512,517,532-533
vPC status
id   Port   Status Consistency Reason                     Active vlans
100  Po100  up     success     success                    433
102  Po102  up     success     success                    433
103  Po103  up     success     success                    433
104  Po104  up     success     success                    433
105  Po105  up     success     success                    433
106  Po106  up     success     success                    433
107  Po107  up     success     success                    433
108  Po108  up     success     success                    433
109  Po109  up     success     success                    433
110  Po110  up     success     success                    434
111  Po111  up     success     success                    434
112  Po112  up     success     success                    452
113  Po113  up     success     success                    432
114  Po114  up     success     success                    432
115  Po115  up     success     success                    432
116  Po116  up     success     success                    432
117  Po117  up     success     success                    432
121  Po121  up     success     success                    412,414,416-417,451
123  Po123  up     success     success                    412,414,416-417,451
125  Po125  up     success     success                    412,414,416-417,451
126  Po126  up     success     success                    412,414,416-417,451
127  Po127  up     success     success                    412,414,416-417,451
129  Po129  up     success     success                    412,414,416-417,451
130  Po130  up     success     success                    412,414,416-417,451
131  Po131  up     success     success                    412,414,416-417
132  Po132  up     success     success                    412,414,416-417
134  Po134  up     success     success                    413,418
135  Po135  up     success     success                    409-410,501,504
From this outputs seems like vpc is fine.
Is the problem still observed on this chassis?
Check "show logging log" for possible reasons of traffic cut. Also I would suggest you to open a TAC case asap - because it would be difficult to troubleshoot iafter some time.
Alex
I will.
Thanks Alex.
If you can, you can follow the case. The number is:SR 621610513
Pablo.
I will follow it.
I see that you already got experienced engineer assigned to the service request - I'm sure the issue will be resolved soon.
Alex
