Snapshot backup with VM
michalsabat
I want to ask You could I do snapshot backup on these services and is there any requirements:
CUCM Active Master Version: 10.5.1.10000-7
Unified CM Voice/Video Active Version 10.5.1.10000-7
CCX Active Version 10.6.1.10000-39
TPCUCM Active Version 10.5.1.10000-7
Cisco TP Server Version 4.2(4.18)
Expressway X8.6.1
Ganesh Hariharan
Hi Michalsabat,
Snapshot is copy of the virtual machine's disk file (VMDK) at a given point in time. Snapshots provide a change log for the virtual disk and are used to restore a VM to a particular point in time.
If these application are running on VM then i dont think it should have any problem in taking snapshot of these images.
Hope it Helps.
-GI
Rate Helpful Posts
Thank You.
But I need more indormatin.
I found that in some case You coan do snapshot only when service is idle.
Thank You.
Ok, I hope below link would give more informtion.
As per the informtion i tried to fetch they say "Snapshot is not supported except for Unity at this time"
https://communities.cisco.com/message/64385
http://docwiki.cisco.com/wiki/Unified_Communications_VMWare_Requirements#VMware_Snapshots
Hope it Helps..
-GI
Rate if it helps
