stacked cigesm
nyi gbe
What internal links are used when 6 cigesms 3110 are stacked together, still 0/15 and 0/16? And when Cigesm uses it is own uplinks for management, do you still have to configured any vlan on internal links to MM? Maybe servers vlan?
Nyi
Rick1776
Level 5
Level 5
All addresses are associated with a VLAN. An address can exist in more than one VLAN and have different destinations in each. Multicast addresses, for example, could be forwarded to port 1 in VLAN 1 and ports 9, 10, and 11 in VLAN 5.
Each VLAN maintains its own logical address table. A known address in one VLAN is unknown in another until it is learned or statically associated with a port in the other VLAN. Addresses that are statically entered in one VLAN must be configured as static addresses in all other VLANs or remain unlearned in the other VLANs.
The the following link is a great reference
https://www.cisco.com/c/dam/en/us/td/docs/switches/blades/igesm/software/release/12-1_22_ay/configuration/guide/59P4376.pdf
https://www.cisco.com/c/en/us/td/docs/switches/blades/3110/hardware/quick/guide/1800801.html#wp34189
