Storage Connectivity with Nexus 5548
smartboy2255
Hi all,
How to do storage connectivity in N5K. Is is possible to connect my storage in N5k normal port or we have to use FCoE ports.What is the config required for the Same.
Thanks in advance..
Ajith
Lo,
To connect Native FC/FCoE into any port on a N-5548 you would require the N-5548UP model, Short for Unified Ports meaning the ports can take FC/FCoE/Eth. If you have a N-5548P you will require one of the expansion cards for your SAN connectivity as all fixed port are Eth only.
The expansion modules available is on the data sheet here.
The configuration guides are available here.
