Strange script
a.giorgi
Level 4
Level 4
Hi there:
I have a N7K that has a strange behaviour for me
When I connect to console after the welcome message a command is executed
In my case is 'terminal color':
User Access Verification
N7K1 login: admin
Password:
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
`terminal color`
N7K1#
I can't see this command in the running config
The question is where is this command?
I search for a default script and I found there are a script language called Phyton that allows you to write fancy scripts
But I don't thing this is tha case because the bootflash:scripts folder is empty
Any clues?
Thank you in advance
Al
Steve Fuller
Level 11
Level 11
Hi Al,
Take a look in the bootflash and check whether you've a file called .rc.cli. This file is added when you run the terminal color persist command and is then executed each time logs in to the switch.
If the file exists, remove it and the terminal color command should no longer be run when user logs in.
Steve Fuller
Level 11
Level 11
Hi Al,
a.giorgi
Level 4
Level 4
Thank you Steve!
Best regards
Al
