02-15-2022 12:35 PM
I am trying to get a fresh install of Windows Server 2016 working on UCS B-Series blade with UEFI and boot from SAN and seem to be hitting a brick wall.
The OS is installed and I can see the Windows Boot Manager entry and the EFI files are present. However, every boot loads the logo and then stops with:
The operating system couldn't be loaded because the kernel is missing or contains errors. File: \Windows\system32\ntoskrnl.exe Status: 0xc0000185
I have tried different media with no luck. I can see the file is present if I load a LiveCD.
This is connecting to a PURE storage array over FC and we already use boot from SAN for our ESXi hosts running on the same blade chassis.
07-19-2022 06:43 AM
Were you able to resolve this issue? I'm seeing the same issue with UCS-B booting from a PURE SAN over FC.
10-19-2022 05:01 AM
Same issue here, UCS firmware on 4.1(2b).
10-27-2022 07:05 AM
Recall a case a few years ago where that was related to compatibility: Pure storage only supports 4MB SCSI commands but Microsoft Windows sends 8MB SCSI commands during UEFI boot from SAN operations
Do you have the option to try booting legacy (non-uefi) ?
Kirk...
12-17-2022 10:34 AM
Same issue here, anyone found a fix for it yet?
Regards. Team Storageboxdirect
01-15-2023 03:19 AM
Same issue here with UCSM 4.2(1f), B200M4, Pure array on FC and Windows 2k19.
Impossible to boot windows after complete uefi install. Error 0xc000007c, ntoskernel missing or corrupt. I tried to repair the boot with a custom iso (vic driver injected), no result. I also tried to run "sfc /scannow" on C: partition from WinPE but no corruption found.
Had to switch to legacy boot type. I'm in a lab environment so it's not a big deal.
Anyone opened a case to Cisco or Pure ?
