03-07-2015 11:19 PM - edited 03-01-2019 07:50 AM
Hello Community,
I need your kind help!
We have a customer who has a Nexus 7000 (C7010) and he wants to upgrade the DRAM on the SUPs from 4GB to 8GB, then upgrade the N7K-C7010-FAB-1 modules to N7K-C7010-FAB-2 modules, and finally insert a new N7K-F248XT-25E module.
Please find some useful outputs below:
sh version
Cisco Nexus Operating System (NX-OS) Software
Software
BIOS: version 3.17.0
kickstart: version 4.2(6)
system: version 4.2(6)
BIOS compile time: 03/23/08
kickstart image file is: bootflash:/n7000-s1-kickstart.4.2.6.bin
kickstart compile time: 5/30/2010 8:00:00 [07/31/2010 19:59:25]
system image file is: bootflash:/n7000-s1-dk9.4.2.6.bin
system compile time: 5/30/2010 8:00:00 [07/31/2010 20:30:14]
Hardware
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
Intel(R) Xeon(R) CPU with 4135816 kB of memory.
Processor Board ID JAF1437BQMA
Device name: switch
bootflash: 2000880 kB
slot0: 2074214 kB (expansion flash)
sh module
Mod Ports Module-Type Model Status
1 48 1000 Mbps Optical Ethernet Modul N7K-M148GS-11 ok
2 48 1000 Mbps Optical Ethernet Modul N7K-M148GS-11 ok
3 48 1000 Mbps Optical Ethernet Modul N7K-M148GS-11 ok
4 48 1000 Mbps Optical Ethernet Modul N7K-M148GS-11 ok
5 0 Supervisor module-1X N7K-SUP1 ha-standby
6 0 Supervisor module-1X N7K-SUP1 active *
7 48 10/100/1000 Mbps Ethernet Module N7K-M148GT-11 ok
8 48 10/100/1000 Mbps Ethernet Module N7K-M148GT-11 ok
Xbar Ports Module-Type Model Status
1 0 Fabric Module 1 N7K-C7010-FAB-1 ok
2 0 Fabric Module 1 N7K-C7010-FAB-1 ok
3 0 Fabric Module 1 N7K-C7010-FAB-1 ok
sh inventory
NAME: "Chassis", DESCR: "Nexus7000 C7010 (10 Slot) Chassis "
PID: N7K-C7010 , VID: V02 , SN: TBM14343189
NAME: "Slot 1", DESCR: "1000 Mbps Optical Ethernet Module"
PID: N7K-M148GS-11 , VID: V03 , SN: JAF1436BTTP
NAME: "Slot 2", DESCR: "1000 Mbps Optical Ethernet Module"
PID: N7K-M148GS-11 , VID: V03 , SN: JAF1436BTTA
NAME: "Slot 3", DESCR: "1000 Mbps Optical Ethernet Module"
PID: N7K-M148GS-11 , VID: V03 , SN: JAF1435CSNM
NAME: "Slot 4", DESCR: "1000 Mbps Optical Ethernet Module"
PID: N7K-M148GS-11 , VID: V03 , SN: JAF1436BTSQ
NAME: "Slot 5", DESCR: "Supervisor module-1X"
PID: N7K-SUP1 , VID: V09 , SN: JAF1437BQGH
NAME: "Slot 6", DESCR: "Supervisor module-1X"
PID: N7K-SUP1 , VID: V09 , SN: JAF1437BQMA
NAME: "Slot 7", DESCR: "10/100/1000 Mbps Ethernet Module"
PID: N7K-M148GT-11 , VID: V07 , SN: JAF1416DBAB
NAME: "Slot 8", DESCR: "10/100/1000 Mbps Ethernet Module"
PID: N7K-M148GT-11 , VID: V07 , SN: JAF1427CTCA
NAME: "Slot 11", DESCR: "Fabric card module"
PID: N7K-C7010-FAB-1 , VID: V04 , SN: JAF1437BPCB
NAME: "Slot 12", DESCR: "Fabric card module"
PID: N7K-C7010-FAB-1 , VID: V04 , SN: JAF1437BPFF
NAME: "Slot 13", DESCR: "Fabric card module"
PID: N7K-C7010-FAB-1 , VID: V04 , SN: JAF1437ATKN
NAME: "Slot 33", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Power Supply"
PID: N7K-AC-6.0KW , VID: V01 , SN: DTM143503U0
NAME: "Slot 34", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Power Supply"
PID: N7K-AC-6.0KW , VID: V01 , SN: DTM143503TC
NAME: "Slot 36", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Fan Module"
PID: N7K-C7010-FAN-S , VID: V01 , SN: FOX1433XA8K
NAME: "Slot 37", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Fan Module"
PID: N7K-C7010-FAN-S , VID: V01 , SN: FOX1433XA8G
NAME: "Slot 38", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Fan Module"
PID: N7K-C7010-FAN-F , VID: V02 , SN: FOX1434XB2L
NAME: "Slot 39", DESCR: "Nexus7000 C7010 (10 Slot) Chassis Fan Module"
PID: N7K-C7010-FAN-F , VID: V02 , SN: FOX1434XB41
I've been studying a lot this activity and I found in the documents that 8GB RAM will NOT work unless you have 5.1(1) or later (current image is 4.2(6)). So I'm thinking of doing this activity using multipath ISSU as follows:
1 | Upload both 5.2(7) and 6.2(8a) images on the flash of both supervisor engines |
2 | |
2.1 | Install the image 5.2(7) on both supervisor engines |
2.2 | After switch comes up verify that everything came up successfully |
3 | power off the switch |
4 | |
4.1 | remove both supervisors |
4.2 | upgrade DRAM on both supervisors |
4.3 | Install both supervisors and verify that everything came up successfully and new DRAM is recognized |
5 | |
5.1 | Install the image 6.2(8a) on both supervisor engines |
5.2 | After switch comes up verify that everything came up successfully |
6 | |
6.1 | power off the switch |
6.2 | upgrade the fabric modules |
6.3 | insert the 10gig module |
7 | power on the switch and make sure everything is working fine |
Does this sound like a good plan ? Has anybody tried such a move before and maybe you can share your experience with me?
Also, there is some information in the 6.2 release notes that don't add up:
Table 6 says that you can perform an ISSU from 5.2(7) to 6.2(8a).
Table 8 says that a multipath ISSU can be performed from 5.2(7) to 6.2(6b) but when I look at table 6 I cannot see that ISSU is supported from 5.2(7) to 6.2(6b) so which information is correct? I'm confused here!
Thanks a lot for the help guys !!
