VPC failed with interface status shown as "vpcCmpFai"
prachaya_k
Hi All,
I am trying to do DCI between 2 pair of Nexus 9508 using VPC. However, on one of the NEXUS is failed to do VPC. I noticed the status of the physical interface, it shown as "vpcCmpFai"
Sh int e2/1 status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth2/1        --                 vpcCmpFai trunk     full    auto    10Gbase-LR
NX1-1(config-if)#
NX1-1(config-if)#
NX1-1(config-if)# Sh int e3/1 statu
Eth3/1        --                 vpcCmpFai trunk     full    auto    10Gbase-LR
NX1-1(config-if)#
NX1-1(config-if)#
NX1-1(config-if)# Sh int po 98 statu
Po98          --                 noOperMem trunk     full    auto    --
NX1-1(config-if)#
**E2/1 and E3/1 are member of Po98**
Anyone experienced this error before, please help advise what to do to fix it?
11 Replies 11
Rick1776
Level 5
Level 5
Can you share the output from show vpc consistency-parameters global
I believe that is a compatibility issue.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/N5K_Troubleshooting_Guide/n5K_ts_vpc.pdf
Hi Rick1776
Yes, there is an incompatibility issue. But again, I do not know why it is giving this issue. I re-check my configure and they are exactly the same on both side.
See below for output of show command:
Sh vpc consis vpc 98
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
STP Port Type               1     Edge Trunk Port        Edge Trunk Port
STP Port Guard              1     Root                   Default
STP MST Simulate PVST       1     Default                Default
lag-id                      1     [(1000,                [(1000,
                                  0-23-4-ee-be-a, 8062,  0-23-4-ee-be-a, 8062,
                                  0, 0), (1000,          0, 0), (1000,
                                  0-23-4-ee-be-1e, 8062, 0-23-4-ee-be-1e, 8062,
                                   0, 0)]                 0, 0)]
mode                        1     active                 active
delayed-lacp                1     disabled               disabled
Speed                       1     10 Gb/s                10 Gb/s
Duplex                      1     full                   full
Port Mode                   1     trunk                  trunk
Native Vlan                 1     1                      1
MTU                         1     1500                   1500
LACP Mode                   1     on                     on
Interface type              1     port-channel           port-channel
Admin port mode             1     trunk                  trunk
Switchport Isolated         1     0                      0
vPC card type               1     N9K EOR LC             N9K EOR LC
Allowed VLANs               -     482-483,910-939,960-97 482-483,910-939,960-97
                                  9                      9
Local suspended VLANs       -     -                      -
Here is configure on NX-1
interface port-channel98
  switchport mode trunk
  switchport trunk allowed vlan 482-483,910-939,960-979
  spanning-tree port type edge trunk
  spanning-tree bpduguard disable
  vpc 98
interface Ethernet2/1
  channel-group 98 mode active
interface Ethernet3/1
Here is configure on NX-2
  vpc 98
As you can see, I do not have any ROOT Guard enabled at all on these port but why the show command said one side has ROOT guard and the other is default?
###Note###
I also have these configure enable at global
spanning-tree port type edge bpduguard default
spanning-tree port type edge bpdufilter default
Are module 2 and 3 the same?
 Also why do you have this on port type edge trunk?
Os this just connecting to an server?
Hi Rick1776
 - Yes, Module 2 and 3 are the same
 Also why do you have this on port type edge trunk? Or this just connecting to an server?
 - As per best practice on page 62 [Configure the vPC used for DCI as spanning-tree port type edge (i.e port fast) to fasten port state forwarding mode when port is operationally up]
Just saw this,your spanning tree types are different on both sides.
Both sides have to be the same
Hi Rick1776
I'm not sure what you mean. Both side are the same as you can see from below:
This is interface po98 on NX-1:
  vpc 98
This is interface po98 on NX-2:
  vpc 98
What I meant was on the physical interface you have switchport mode trunk.
For the physical interfaces I would have the following configuration.
no shut
Have the basic configuration under the physical interface and then configure the port-channel.
Sometimes the order of operations messes things up.
Under the physical interfaces like 2/1 not the port channel.
vpc 98
switchport mode trunk This should not be here
switchport mode trunk this should not be here
under Int 2/1 and 3/1 you should just have
channel-group 98
no shut
configure all other interfaces under int po 98
Hi Rick1776
Ok, now I get you..
i will try as you suggested and will let you the outcome.
thank you very much for helping
Not a problem happy to help.
