VPC, VPC Peer-links and VDC
ar
I have 2 7Ks and will run VPC and multiple VDCs.
Should it be a separete VPC Peer-link and keep-alive link per VDC?
I am not sure but I guess yes since a physical interface should be allocated to a VDC.
I just need confirmation.
thanks
Jerry Ye
Yes, if you are having 4 VDCs with vPC, you will need 4 separate vPC peer-links. VDC is a physical separation (even though it is the same box) and it cannot communicate across VDC.
HTH,
jerry
Jerry Ye
HTH,
jerry
thanks again Jerry.
