02-25-2020 11:07 PM
I have a lab where I have deployed a triangle of bgp evpn NXOS 9000v switches. On each side of the triangle a have a host.
Lets say the following:
Host A with mac a.a.a.a in side A of the triangle
Host B with mac b.b.b.b in side B of the triangle
Host C with mac c.c.c.c in side C of the triangle
All hosts are in the same subnet and all VTEPs as different ASs, so this is all eBGP.
Host A can reach host B and C perfectly going through its directly connected link from its VTEP.
The problem comes that, when I disconnect for instance link from VTEP between host A and host B. I can still reach host C but unable to reach host B eventhough through BGP EVPN table I see AS B + C. The VTEPs has the l2route mac installed on each side and when I check the packets in wireshark I can see the packet flowing through the triangle but no response back. The same happens if I try to ping from host C to A. Packet ICMP reahes from C to A, but no response...
Any clue what Im missing.
I think that im missing a command that when in the AS path when there is 2 or more ASs in the path I should allow it...
Please help
Amit
02-26-2020 01:18 AM
04-07-2020 12:57 AM
Could be a bug. Have you checked in a bug tracker? What is NX-OS version and model of the leaves?
04-07-2020 11:49 PM
Hi Abzal,
Thanks for your reply.
The version of the VIRL nodes is 9.2.3 NX-OSv
I´ve looked at the documentation and I wasn´t able to find something about this issue.
I think yes, you are correct, I can imagine this is a bug because, if I do show commands, the control-plane is correct but the data-plane doesn´t behave as expected. In other words, my personal conclusion that this is a data-plane bug.
Best regards
Amit
