Would QSFP-H40G-AOC15M work to interconnect 2348UPQ to a Nexus 5600 switch
We are in the final stages of a datacenter rebuild and I was wondering if we could use the
QSFP-H40G-AOC15M  to connect the 2348UPQ fex to a 5600 nexus switch?
If not what could we use to interconnect the fex and switch as they are about 30 - 40 ft apart?
Thanks in advance
Manny Nkiwane
Farhan Mohamed
I think you can use it, I am not talking about distance here, But i guess the Copper AOC breakout cables can be used for connection between, 2348 to 5600 nexus switch.
Please also check the NX-OS release version you are using, Also check the guide i have attached so it can give you more information on the compatibility and OS release.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.pdf
