11-04-2010 09:29 AM - edited 03-03-2019 06:06 AM
Hello everyone, I'm trying to get CCNA certified so I bought a 1721 off of someone. I turned it
on and it went right into rommon. I did some googling and I kept getting the magic number error etc. So I decided
to reload the bin file. I have loaded 2 different ones and they both do the same thing, they go back to rommon..
Short story
I setup the IP information for tftp, then I have it download the bin file, I think do something along the lines of either
b flash: (filename)
or
boot (filename)
it does it's thing, I type reset, it resets (sometimes 3 times in a row) and then
<rommon>
The Long story..
rommon 14 > tftpdnld
IP_ADDRESS: 192.168.1.200
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.1.1
TFTP_SERVER: 192.168.1.16
TFTP_FILE: c1700-advsecurityk9-mz.124-12c.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
Receiving c1700-advsecurityk9-mz.124-12c.bin from 192.168.1.16 !!!!!!!!!!!!!!!!!
File reception completed.
Copying file c1700-advsecurityk9-mz.124-12c.bin to flash.
Erasing flash at 0x60fe0000
Programming location 60cd0000
rommon 15 > boot c1700-advsecurityk9-mz.124-12c.bin
program load complete, entry point: 0x80008000, size: 0xcde830
í
System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2001 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 4K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Sizing flash
Exiting init
C1700 platform with 98304 Kbytes of main memory
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
rommon 1 > IP_ADDRESS=192.168.1.200
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.1.1
rommon 4 > TFTP_SERVER=192.168.1.16
rommon 5 > TFTP_FILENAME=c1700-advsecurityk9-mz.124-12c.bin
rommon 6 > tfpdnld c1700-advsecurityk9-mz.124-12c.bin
monitor: command "tfpdnld" not found
rommon 7 > tftpdnld c1700-advsecurityk9-mz.124-12c.bin
usage: tftpdnld [-r]
Use this command for disaster recovery only to recover an image via TFTP.
Monitor variables are used to set up parameters for the transfer.
(Syntax: "VARIABLE_NAME=value" and use "set" to show current variables.)
"ctrl-c" or "break" stops the transfer before flash erase begins.
The following variables are REQUIRED to be set for tftpdnld:
IP_ADDRESS: The IP address for this unit
IP_SUBNET_MASK: The subnet mask for this unit
DEFAULT_GATEWAY: The default gateway for this unit
TFTP_SERVER: The IP address of the server to fetch from
TFTP_FILE: The filename to fetch
The following variables are OPTIONAL:
TFTP_VERBOSE: Print setting. 0=quiet, 1=progress(default), 2=verbose
TFTP_RETRY_COUNT: Retry count for ARP and TFTP (default=7)
TFTP_TIMEOUT: Overall timeout of operation in seconds (default=7200)
TFTP_CHECKSUM: Perform checksum test on image, 0=no, 1=yes (default=1)
Command line options:
-r: do not write flash, load to DRAM only and launch image
rommon 8 > TFTP_FILE=c1700-advsecurityk9-mz.124-12c.bin
rommon 9 > tftpdnld
rommon 10 > help
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis display instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
rommon 11 > b flash:
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
rommon 1 > reset
Í
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
ý
Clearing bss
Enabling interrupts
Reading cookie
Sizing NVRAM
Sizing flash
Exiting init
rommon 1 >
Help me Cisco experts, you're my only hope..
Solved! Go to Solution.
11-09-2010 02:13 PM
No, it's not normal for a router to restart 3 or 4 times. It is normal for flash: to be the only device listed in "dev" since that's the only file system on the 1700. There's nothing else that we can try until the RAM gets swapped out.
11-04-2010 02:48 PM
Unfortunately, I can't say why it's going to rommon, because all we get is this:
ý
There should be some sort of error between those two lines. Regardless, I would try two things. First, reconfigure the configuration register to the default value ("confreg 2102" from rommon). Then use the -r flag for tftpdnld which will bypass flash entirely and essentially do a tftpboot. If it happens to successfully boot then, erase the flash (which will also format it), and download the image once again onto flash. If it still doesn't work, I'd point my finger at the RAM in the router.
11-05-2010 06:34 AM
Neither seems to work. Is it normal for the router to restart 3 or 4 times in a row, also, should I have more than one thing listed when I type dev?
11-09-2010 02:13 PM
11-10-2010 09:52 AM
Well I just ordered some more ram and I hope that solves the problem.
11-15-2010 09:45 AM
Get this man a cookie, sure enough, I swapped out the RAM and everything acted right. Thanks for the help.
