2620 low memory messages
glen.grant
We are getting traps that say memory is below 25% on this 2620 . It is running ios version 12.2.26 ip plus code . It has 48 meg DRAM and 16 meg flash . Nothing showing up in logs on the router as a problem .
I tried playing around with the IO mem size where it is set at 25% currently but we are still getting this error . Should i try allocating more IO mem ? I have run the show proc mem output thru the "output interpreter" and it doesn't find any problems . This box is only running 1 fast ether and 1 serial line with very little traffic on it . IT has been reloaded to no avail . Any input ????
jolmo
Level 4
Level 4
Hi Glen, can you post the first lines of the output from "show memory summary" ?
Head total(b) Used(b) Free(b) Lowest(b) Largest(b)
81C3B5EC 8145428 4932144 3213284 2833200 2937936
2400000 12582920 1721720 10861200 10861200 10861148
I don't see anything strange. Did you receive this message from Ciscoworks ?
the traps are being sent to our alert tool . I'm thinking that the 12.2.26 image may just be taking up too much memory though the box meets "minimum" requirements for this release. I may downlevel it to the latest 12.1 GD release which is 12.1.25 I believe and the requirements are a little less at it only needs 40 meg DRAM .
