3548 switches not enough flash
jhilton
Trying to upgrade 3548's to new image using RME. I get error message that there is not enough flash. This has worked in the past. I thought that the old image was just overwritten by the new image.
6 Replies 6
milan.kulik
Level 10
Level 10
Which IOS version are involved?
There was a CSCec11178 bug half a year ago with similar symptoms.
Milan
Upgrade from c3500xl-c3h2s-tar.120-5.WC9.tar to
c3500xl-c3h2s-tar.120-5.WC10.tar
Have you tried the CLI upgrade?
If it also fails, I'd recommend to open a TAC case.
Milan
Upgrade worked ffine using CMS. I must have a Ciscoworks issue. Will open a TAC case. Thanks for the help
Just for sure:
Do you have the latest IDU installed?
Milan
Yes 8.0
