10-27-2004 10:37 AM - edited 03-02-2019 07:34 PM
I got two Cisco WS-C3548XL, each one have a GBIC 1000Base-SX tranceiver (WS-5484) and they are connected together with a fiber. It's work very well.
Both have IOS version 12.0 (5.3)WC(1)
Here my problem:
We have decided to change this topology and we are trying to connect the Cisco switches in a SMC Tigergiga 8624T switch via SFP GBIC Transceiver 1000Base-SX (SMBGSLCX1).
We are getting connectivity on TigerGiga but nothing on the 3548Xl switch. We have configured both switch with no negociation and no flowcontrol.Both Speed are set manually. Fiber link are good for sure !
What could be wrong?
(trying all setting possibilities?)
Is there any compatibility issues with SMC and Cisco transceivers ?
Thank
10-27-2004 11:47 AM
I would say it was a negotiation problem, but you said you have it turned off. My next guess would be incompatability.
10-27-2004 02:40 PM
The problem could also be the switch IOS image. What you're running is over three years old (18-July-2001). The Catalyst 3500XL series is up to 12.0(5)WC10 now (07-June-2004).
I had problems a couple years ago with a new Catalyst 3550-12G talking Gigabit to a 3Com switch over an SX GBIC connection. A software upgrade to a more current version and configuring "speed nonegotiate" on the Cisco's GBIC interface was the solution.
11-02-2004 05:29 PM
OK now i upgrade to IOS 12.0(5)WC10 and still not working.
Config:
speed full duplex
no flowcontrol
no negociation
Still no connection on the Cisco interface.
Do you think that flowcontrol is needed?
thank
11-02-2004 09:27 PM
Have you tried this:
(config-if)#switchport nonegotiation
This will turn off the DISL/DTP negotiation for forming the trunk between the link. Make sure the port is set to access.
regards,
11-03-2004 06:49 AM
Sorry but the command:
do not exist
Here what i have.
(config-if)#switchport ?
access Set access mode characteris
mode Set trunking mode of the in
multi Set characteristics when in
priority Set 802.1p priorities
trunk Set trunking characteristic
voice Voice appliance attributes
11-03-2004 11:05 AM
1000 Base SX requires negotiation! Turn it back on...
Also update your sofware, they have WC(9a) out now.
11-03-2004 04:20 PM
I already have WC(10),
Bytheway when negotiation is on its for negotiating what? (Flowcontrol or speed or duplex)
I also send my problem to SMC engineer maybe the problem is on there side.
Continue finding answer, i trying all your answer, keep the good work. Thank i appreciate !
11-04-2004 06:28 PM
Finally its now Working.
After talking with the guys at SMC:
I upgraded the firmware of the SMC Switch.
Here the congig:
SMC: Autonegotiation,1000f, FC, Sym
Cisco: Duplex auto, negotiation auto, flowcontrol
Thank you guys for your help!!
