3750 Load balancing problem on dual path
czj7l9
Hi,I have a 3750 switch wich is connected to a 3600 Cisco router with two redundant links.
The layout is 3750 FE 1/0/1 connected to a 3600 ETH 0/0 and the FE 1/0/2 to ETH 0/1.
A Pc is also connected to int 0/3 of the 3750 switch.
In this model I used dual path layer 3 redudances model and using EIGRP for load balncing and failure mechanism betweeen switch and router.
Now, when I send a packet from the Pc to a loopback configurated on Cisco 3600 router the path used remain all the same(see by Sniffer) and this is not good for load balancin.The output of the "sh ip cef exactly route"don't match wath seen by sniffer.
Thanks.
mchin345
Level 6
Level 6
You might be running into a Cisco Bug here. The Bug-Id is:CSCdi72459
