7200 NPE-200 flash disk issue
rvandommelen
Hi all,
I was wondering if it is possible to boot a
7200NPE-200 from a flash disk. I've read some issues on this that a primairy boot cannot work from a flash disk and has to be done from normal flash.
How can I boot the system after normal startup from the flash disk ?
Does anybody have a clue ? The bootflash code is 12.0.17S
Best regards,
Ronald van Dommelen
The Netherlands
josrankin
"The 48-MB, 64-MB, and 128-MB Flash Disk are not supported with the NPE-100, NPE-150, or NPE-200 in a Cisco 7200 series system router or Cisco uBR7200 series universal broadband router."
http://www.cisco.com/univercd/cc/td/doc/product/core/7200vx/72vxfru/5819fdsk.htm#20745
You can use a non-ATA flash card (20MB is part number MEM-I/O-FLC20M=) to boot with the NPE-200.
