7204VXR with NPE225 boot problem
jtb
We have a 7204VXR chassis with a NPE225 module together with a C7200-I/O-2FE/E port adaptor that has begun to fail to boot. I've pasted the console output that's displayed at boot below:
System Bootstrap, Version 12.0(19991120:010612) [nlaw-conn_4xe_ECC 112], DEVELOPMENT SOFTWARE
Copyright (c) 1994-1999 by cisco Systems, Inc.
C7200 platform with 131072 Kbytes of main memory
getdevnum warning: device "boot flash" has size of zero
open: read error...requested 0x4 bytes, got 0xffffffff
trouble reading device magic number
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
rommon 1 > dir slot0:
File size Checksum File name
1121 bytes (0x461) 0xcf3dc1e6 dst
12090908 bytes (0xb87e1c) 0xf208b7ab c7200-is-mz.122-2.t.bin
rommon 2 >
from reading several relevant Cisco documents I am beginning to feel we are lucky this router has ever booted:
http://www.cisco.com/warp/public/770/fn12932.html
http://www.cisco.com/warp/public/770/fn13061.shtml
The part numbers of our equipment is as follows:
2F/E port adaptor: 800-07114-04-A0 (sticker on outside of adaptor)
2F/E printed ciruit assembly: 73-5003-04-B0
NPE225 processor : 73-3453-04-A0 and 73-4043-02-B0
Thanks for any help any-one can provide...this equipment is not covered by warranty.
Not applicable
1 of 2 things could be causing this.
1. There is no/no valid bootflash image on the flash of the IO controller.
2. There is no FLASH SIMM installed in the IO controller.
You can check this by using "show bootflash". If it reveals nothing then your problem lies there. Otherwise try to perform a format and then copy an image there, failing that a physical inspection will be needed.
Frank
