A peculiar Problem about browsing sites from outside
kjanakiraman
I have a cisco router with two T1 lines running BGP and it is connected to a Cisco 2950 switch and to a Cisco Pix firewall. Every day at a particular time our web sites are not accessable from outside using both by name and ip address from outside. But using telnet i can open the particular port (80) from outside. Even my web site which is outside the firewall is not accessble from outside. But when i reboot either the router or the firewall everything comes back to normal. Is there anything i need to check? What makes very peculiar is the fact that the website which is outside the firewall not working at that time and starts working when i reboot the firewall?
Thanks in Advance
dbellazetin
Level 4
Level 4
Sounds interesting. I would check the cpu process on your devices when this happens to see if they are very high. Verifying the config is important too. If you could post configs and change the IPs that would be helpful.
Daniel
