08-20-2005 10:49 PM - edited 03-02-2019 11:46 PM
Hi all,
When I issued 'show proc cpu', there is somewhat higher Process ID than any other Process.
That is 'Calhoun LED Proc' field.
What is that ?
CPU utilization for five seconds: 15%/2%; one minute: 15%; five minutes: 17%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 12 762 15 0.00% 0.00% 0.00% 0 Load Meter
3 288 127 2267 0.00% 0.00% 0.01% 1 Virtual Exec
4 1116 385 2898 0.00% 0.03% 0.00% 0 Check heaps
5 1480 487 3039 0.08% 0.03% 0.02% 0 Pool Manager
6 4 2 2000 0.00% 0.00% 0.00% 0 Timers
7 56 17 3294 0.00% 0.00% 0.00% 0 Entity MIB API
8 36 761 47 0.00% 0.00% 0.00% 0 HC Counter Timer
9 26100 41317 631 0.98% 0.68% 0.75% 0 ARP Input
10 756 637 1186 0.08% 0.02% 0.00% 0 Net Input
11 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
12 756 1540 490 0.00% 0.00% 0.00% 0 Net Background
13 12 89 134 0.00% 0.00% 0.00% 0 Logger
14 108 3782 28 0.00% 0.00% 0.00% 0 TTY Background
15 372 3791 98 0.00% 0.00% 0.00% 0 Per-Second Jobs
16 352 762 461 0.00% 0.00% 0.00% 0 Compute load avg
17 616 64 9625 0.00% 0.01% 0.00% 0 Per-minute Jobs
18 0 2 0 0.00% 0.00% 0.00% 0 Calhoun Storm Co
19 361648 84185 4295 9.50% 9.57% 9.45% 0 Calhoun LED Proc <-- THIS !!
20 45040 7457 6039 1.14% 0.99% 0.00% 0 Calhoun Statisti
Thanks in advance ....
08-21-2005 06:21 AM
What you are seeing is normal. The "Calhoun LED Proc"
is a process which does a number of things on each
physical port:
- Update statistics and error counters in port LED config, to update the blink profile.
- For each port, calculate the next color to be displayed based on the blink profile and the mode.
09-05-2005 06:53 PM
Thanks it's helpful..^^
