ATM route-bridge
alvincdc
I have a DSL client with the following configuration,
interface ATM4/ima1.5 point-to-point
bandwidth 256
ip address 210.3.17.65 255.255.255.240
atm route-bridged ip
pvc 0/38
encapsulation aal5snap
When his connection goes down. He can ping the gateway(210.3.17.65) but cannot go outside this.
From my end, I can ping also 210.3.17.65 but cannot go beyond his LAN. My client is saying that the problem is on our router.
Can someone explain?
gmarogi
Level 5
Level 5
It is indeed puzzling. You can probably check your routing table and use some IP or ATM related debugs to see what is happening.
