backup interface
carl_townshend
when I use this command, does it automatically route through it ? how would i put my static routes in this case, would I need 2, 1 for the normal interface and 1 for the backup interface ?
cheers
17 Replies 17
Hi Carl,
Yes, you need to point to routes to the other end. You can have only two normal static routes pointing to different interfaces and only one will get installed in the routing table as the backup is in standby mode.
HTH, Please rate if it does.
-amit singh
thanks amit, thats what I wanted to know, does the route going to the BRI interface need to have a differnet AD or can they be the same ?
cheers
Carlos
They can be same.
HTH,
-amit singh
