Bandwidht control on catalyest switch
abaghir
I'm looking for a catalyst switch that support bandwidth control on each port e.g ( 64K, 128K )
I have C2950 switch, does it support this feature, if so, Please guide me to the configuration...
Adel
didyap
Level 6
Level 6
The 3550 supports per port rate limiting if that is what you mean by bandwidth control.
You could also use VLANs on the switch and have a router run CAR (committed access rate) on a trunked ethernet interface. The router uses the VLAN tags to control how much bandwidth a particular VLAN can have.
igorj
You can use C2950 traffic policing - although,
range for traffic rates is 1 Mbps to 100 Mbps for
10/100 Ethernet ports and 8 Mbps to 1000 Mbps for
the Gigabit-capable Ethernet ports.
Please se 'C2950: Configuring QoS' for further info:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d84c9.html
/Igor
