Basic enable mode question
ColForbin
On a 3750 aaa new-model is enabled but at the moment it’s just the default settings and I noticed something.
I have a username testuser1 priv 15 with a password set. When I console in with testuser1 it connects to user exec mode. To get into enable mode, enable and the enable secret password work.
what’s the bare minimum I need to do to have console sessions go right to enable mode instead?
I mean aside from disabling aaa new-model
Thanks!
Mark Elsen
  - You  may try : line con 0
                              privilege level 15
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
                              privilege level 15
  M.
       Beauty and terror
      Just keep going
       No feeling is final
ColForbin
always the little things....awesome thanks!
