Block cross network printer sharing
nigel2392
Hello! I have made 2 interconnected networks.
I want the devices from network 1, to not be able to communicate with printer from network 2
I want the devices from network 2, to not be able to communicate with printer from network 1printer sharing, printers
I want the rest of the devices of network 1 to be able to communicate with all devices on network 2, except for the printer ofcourse.
I want the rest of the devices of network 2 to be able to communicate with all devices on network 1, except for the printer.
How would one go about this?
I have searched extensively online, but cannot really find a solution. I have asked my tutor, and he says packet tracer does not support this feature.
Any help is very much appreciated!!!
 This is quite simple. First of all, you need to determine where to place an Access List.  If you want to block devices on network 1 to communicate with a printer in network 2, then, make sense you place your Access List somewhere in the network 1.  Cause dont make sense the packet travel all around the netwok 1 to be blocked on the destination. Did you get it?
 This is perfect possible in PacketTracer.
Hello
Example: Network 1 rtr
Ip access-list extended printer
deny ip any host <printer network2>
Permit ip any amy
int x/x
Ip access-group printer in
Example: Network 2 rtr
deny ip any host <printer network1>
permit ip any amy
int x/x
Kind Regards
Paul
