blocking https traffic... help
Armegeden
Level 3
Level 3
Hello all,
Some of the higher ups are wanting to block some secure webmail traffic and were asking if Cisco had this option.
The only way I can think of is QoS Policy Based Routing... ? Is this correct?
And if so, what would be a basic setup for this scenrio. Like if I wanted to block 443 traffic from a specific subnet range?
Also, anyone know of a link that gives me the rundown on how to setup Policy Based Routing? Like what each step is for...
I've seen a couple threads about this, but the whole setup was kind of obscure to me...
Thanx in advance
nethelper
Level 6
Level 6
Hello Scott,
I am thinking is it not possible in your scenario to simply block TCP port 443 (HTTPS) from accessing the subnet by using an extended access list :
Let's say you want to block HTTPS traffic from subnet 192.168.1.0/24, you could configure an access list as following:
access-list 101 deny tcp any 192.168.1.0 0.0.0.255 eq 443
access-list 101 deny 192.168.1.0 0.0.0.255 any eq 443
access-list 101 permit ip any any
and apply this access to your local interface, e.g.:
interface FastEthernet0/0
ip access-group 101 in
Does that make sense ?
Nethelper
nethelper
Level 6
Level 6
Hello Scott,
Nethelper
Hello Nethelper,
Yes, the extended ACL does make sense. I don't know why I was thinking narrow for Group Policy. I believe this would work.
The company is wanting to block Gmail (abusing chat) and at it's current state, the normal HTTP is blocked via a Software Filter, but HTTPS is still accessable.
Thanks for the reply.
BTW, when is the ideal time to use Policy Routing? Just for load balancing or preferred path type stuff?
