11-02-2001 12:26 AM - edited 03-01-2019 07:12 PM
I have a router cisco 2600 to connect to internet.
Because I only have 128 Kbps for internet access so I want to controll bandwidth for users on the LAN for example, user1 - 64 kbps, user 2 -24 kbps ...). Following is summary about my router configuration:
ip cef
interface Ethernet0/0
ip address 192.168.10.1 255.255.255.0
rate-limit input access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 11 24000 8000 8000 conform-action transmit exceed-action drop
access-list 11 permit 192.168.10.11
access-list 11 permit 192.168.10.12
access-list 12 permit 192.168.10.111
Butwhen I do the test, users can download above the speed I have setup for them !!!
Please help me to fix this problem !!! If CAR can not resolve this problem, pls give me another solution !!!
11-08-2001 12:23 PM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
11-08-2001 01:52 PM
actually I had replied to this question under the case title "need help on CAR"
thanks
steve
