Cat6k-MSFC: DHCP: need help with manual bindings
tnatsukawa
Hi, on my Cat6k-MSFC I'm having trouble setting DHCP manual bindings:
Router(config)#ip dhcp pool Guest
Router(dhcp-config)#host 172.16.69.2
% This command may not be used with network pools.
Router(dhcp-config)#hardware-address 0800.3712.9d76
Am I missing something?
Tatsuo
thisisshanky
Level 11
Level 11
You are probably trying to configure the manual binding in an already existing network pool (a pool with the "network" command already entered).
What you can do is create another pool (which should be a host pool, i.e. no "network" command entered) and just specify the "host" and "hardware-address" commands.
Note that you can create only one manual binding per host pool, but there is no limitation to the number of manual bindings you can have on the router. So if you need multiple manual bindings, create that many host pools.
Hope that helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
Hope that helps!
Sankar Nair
That was it! Thanks, Tatsuo
