11-14-2001 04:39 PM - edited 03-01-2019 07:23 PM
Can anybody please halp on this.
In case of port address translation cisco seems to be statring the inside local/global translated port from 1025 onwards, but why does it retains the translated port number even after clearing the nat translation by using "clear ip nat translation *" command, and takes next port to create translation entry (even if you initiate the connection from same ip).
Any help is highly appreciated.
Thanx in advance
11-20-2001 02:13 PM
The port is tabled separately in memory. To clear NAT overflow translations, youll have to reboot the router. Port assignments will be any port needed >1024. You cannot specify which ports it uses.
11-20-2001 09:37 PM
Thanks poplitz for help, but I have seen this, even though I reboot the cisco it retains the port number, I am using Cisco3660, ios 12.1(3)T.
Any specific reason to retain the port number ??
Thanx in advance
