Choosing the right components
mynewdude
Hi, I'm hoping that the "World Wide Web" can assist me with a very trival problem. We are putting some racks up for delivery to satelites in China, New York and Brazil. As a backup we would like to use the 1760 with either ISDN or analog interfaces. We have these successfully running in Europe but our sales people have made us somewhat unsure. They are telling us of a possibility or different ohm situations on the telco lines that may require different modules than we normally use. We do not yet know what lines we will have but as far as we have been able to find out ISDN(56k US) and POTS are both supported in the US and Brazil. As with China, the story seams to change depending on the hour of day and if China Telecom wants to or not. What we would like to hear is what models of ISDN/POTS modules may be used in the US, China and Brazil. As I said, only for VPN backup purposes at present.
Joe
drolemc
Level 6
Level 6
The ISDN support page is located at http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Technologies:ISDN&viewall=true. There are a number of documents listed there that will help you get these specification.
drolemc
Level 6
Level 6
That seams to be exactly what I needed. Thank you!
