Cisco 1721 with WIC-1DSU-56K4 & ISDN card
brian
I am trying to set up a 1721 with a primary 56K frame connection with ISDN back-up. I have set up dozens of these with 1602's but I cannot get the 1721 to take any service-module 56K commands such as
service-module 56K clock rate 56
service-module 56K clock source line
service-module 56K data-coding normal
service-module 56K network-type dds
service-module 56K remote-loopback
I have tried appling these to S0 and S0.1
What an I missing?
10 Replies 10
deilert
Level 6
Level 6
try to configure the t1 controller
router(conf)controller t1 0/0
router(conf-contr)
I do not have a T1 controller. A show controller only shows the ISDN card which is in the slot WIC 1 and the 56K 4 wire (shows as S0) which is in WIC 0.
can you paste in a sh ver , and the command is sh controller t1
sh controller t1
% Invalid input detected at '^' marker.
Raynham#sho ver
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 21:54 by ealyon
Image text-base: 0x80008124, data-base: 0x807976DC
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Raynham uptime is 2 minutes
System image file is "flash:c1700-y-mz.122-4.YA2.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memory.
Processor board ID FOC07201CP0 (3090679331), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
--More-- 1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC with 56k 4-wire CSU/DSU
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Raynham#
I checked the compatability matrix and you are running code that support it for this box
what happens with the question mark ?
router#(conf-if)service-module ?
The commands are rejected at the s0.1 level where I typically put them on the 1602. They look like they work at the S0 level but a sho running-config afterward so no trace of the commands,
Raynham#config
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line. End with CNTL/Z.
Raynham(config)#service-module
Raynham(config)#interface s0
Raynham(config-if)#service-module ?
56k 56K switching
Raynham(config-if)#service-module 56K ?
clock Service module clock source
data-coding Service module DCE line coding
network-type Service module Network Type/DACS mode
remote-loopback Remote Loopback/RL disable
switched-carrier Service module long distance carrier
Raynham(config-if)#service-module 56K clock ?
rate 56K Module clock rate
source Module clock source
Raynham(config-if)#service-module 56K clock source line
Raynham(config-if)#int s0.1
Raynham(config-subif)#service-module
the reason the commands are rejected on s0.1 is because this is a logical interface . You have to set these parameters on the physical interface
I have set them there but they do not show in the configuration afterwards
If they do not show up it is a default setting
okay, thanks
