I have a 3750 stack with 2 switches. Switches are connected with stack cables. On gig port #2 on each switch I have a fiber going to two Extreme 48si switches. When stack switch # 1 is power cycled I lose connectivity with Extreme 48si #1 through stack switch #1 gig port. Extreme 48si switch #2 continues to function through stack switch #2. I have used a sniffer to capture traffic and do not see the broadcast traffic that should be leaving stack switch #1 gig port to the extreme switch #1.
I have tested using a UTP connection from stack switch #1 to extreme switch #1 and mirrored the traffic and see the broadcast arp packets go from stack switch #1 to the extreme #1 on the UTP port. Is there a command to cause the gig port to "wake-up" after a power cycle?
