INTERFACE NULL0 AND INTERFACE LOOPBACK
jabbar154
How many number of interface null0 and interface loopback could be defined on a router.
Harold Ritter
Level 12
Level 12
There can only be one null interface. The null0 is like a bit bucket therefore you don't need more than one.
As far as the number of loopback interfaces, it should only be limited by the number of IDBs (interface data block) supported by the IOS you run and the memory you have on the router, which would be pretty high in any case.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
m.mazurek
As an example:
#interface loopback ?
<0-2147483647> Loopback interface number
#interface null 0?
<0-0>
hth
mazek
Harold Ritter
Level 12
Level 12
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
