Cisco 3850 switch to Cisco 9200L switch connectivity
Hi All
I wanted to eastablsh a 10GB connection between a Cisco 3850 and a Cisco 9200L on a 10GB Twinax cable
I used a 10GB SFP+ DAC cable this did not respond very well on the 9200L
%PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/1 is not supported
I even used the
service unsupported-transceiver
 This didnt work either, please could some one shed some light on this
Thanks in advance
M02@rt37
Hello @JamesSimpson34554,
Please find here the media type DAC compatible with C9200L.
https://tmgmatrix.cisco.com/?npf=342
Check column "media".
Check ot your specific DAC is in this list.
Best regards
in addition to what @JamesSimpson34554 is suggesting, which SFP module are you using ? Is this a Cisco SFP, or a third-party SFP ?
